Debugging Nets
Hi Experts,
I want to debug some nets in my design. Is it possible to probe those nets outside using Ethernet or UART.
If it is possible than can you provide me with some tutorial links or some document that can give me an idea to implement it. Your suggestions and guidance will be very helpful.
@ukonar,
You can debug the nets using Vivado ILA. Check the following tutorial:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug936-vivado-tutorial-programming-debugging.pdf
--Syed
Hi @syedz
Thank you for your response.
I am presently using ILA to debug the nets. But there is limitation of sample depth in ILA. I can only probe out 131072 samples, which is too small for my application. I want to probe atleast 50 times 131072 samples. What might be the possible way to do it. Please help
