josephprodigy
Download Error
I am try to get reference design of VC128.
Then below error is coming.
We cannot fulfill your request as your account has failed export compliance verification.
Please Help on this
u4223374
Advisor
Advisor
The two common causes are having incomplete account details, or living somewhere that isn't currently friendly with the USA (because the USA restricts exports of "advanced technology", which includes most Xilinx products).
anatoli
Hello @josephprodigy ,
Looks like your Xilinx.com profile is currently blocked and is being screened by our export compliance team and is placed on hold and that is the reason why you are currently unable to generate a license or download Vivado or any other files from Xilinx.
I have contacted the Global Compliance Team (GTC) to verify your profile and to get it unblocked, if all is OK with the profile. I will update you once this is done.
In the future, if you'd encounter the same problem, please contact Xilinx Customer Support (websupport@xilinx.com) (see AR https://www.xilinx.com/support/answers/44043.html for more details) and they will work with GTC team to get this unblock for you then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
josephprodigy
Thanks for the update.
anatoli
Your profile is now active and full access given.
As a recommendation, since your profile was blocked in the first place, there is a chance that each time when you update your Xilinx.com profile in the future, it will get blocked once again. Therefore, please don’t update your profile (unless it is needed to do so) once the profile is re-enabled.
If this happens for you again, please contact Xilinx Customer Support(websupport@xilinx.com) (see AR https://www.xilinx.com/support/answers/44043.html for more details) and we will unblock your profile again then.
Apologies for any inconvenience caused.
Kind Regards,
Anatoli Curran,
Versal Blogs
u4223374
Advisor
Advisor
