ERROR: Unable to find top-level HDL source file for core: vdma. XAPP739
Im trying to implement the application note XAPP739. and im using ISE 14.7. When I compile the files from XAPP739 i Get the following errors. Where do I find these files and how do I implement them?
ERROR: Unable to find top-level HDL source file for core: clock_generator.
ERROR: Unable to find top-level HDL source file for core: axi4.
Ritesh
Tags (3)
Re: ERROR: Unable to find top-level HDL source file for core: vdma. XAPP739
Hi Thanks
I have managed to get it to work. It actually works in ISE 13.2 but doesnt work in ISE 14.7. It is very strange.
Ritesh
Please follow the instruction given in xapp739
Steps to Open and Rebuild the Design
http://www.xilinx.com/support/documentation/application_notes/xapp739_axi_mpmc.pdf
Thanks and Regards
Balkrishan
Hi Thanks
Ritesh
