shrikantb
Enquiry regarding TRD/Graphical reference of ZC702 EK for release v2016.2
Hi All,
I am looking for a pre-built graphical reference/TRD for ZC702 EK
I have used release v2015.2 based TRD with kernel v3.19 from
http://www.wiki.xilinx.com/Zynq+Base+TRD+2015.2 & graphics working well out
of box.
I want to use the release tag v2016.2 kernel v4.4, Is a TRD reference
available for it ?
Got a base reference for it from
http://www.wiki.xilinx.com/Zynq+2016.2+Release but not TRD.
Any pointers or references for TRD/ Graphical ref. based on v2016.2 will
be a great help.
Shrikant
Tags (4)
u4223374
Advisor
Advisor
I can't say for sure (I'm not a Xilinx employee), but given that support for the ZC706 (the "high-end" version of the ZC702) has been frozen with Vivado 2015.4 I'd be a bit surprised if we saw any further releases for the ZC702.
With that said, there's nothing stopping you upgrading the 2015.4 project to 2016.4 (or whatever version you want). The Zynq 7020 is still supported in all new versions of Vivado, and that's likely to remain the case for quite some time. You may encounter issues that need to be worked around, or you may not - it's worth a try anyway.
smarell
Community Manager
Community Manager
This TRD was lasted updated to 2015.4- https://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html?resultsTablePreSelect=documenttype:Targeted%20Reference%20Designs#documentation
Is there any specific reason why you are looking for 2016.2 version?
shrikantb
Thanks for the quick response. Used TRD latest v2015.4 got Graphics up and running on ZC702EK, with kernel v4.0 & u-boot v2015.07.
The specific reason for looking v2016.2 is based on yocto meta-xilinx, I want to use the kernel v4.4 & u-boot 2016.01 with graphical support and want to use the TRD as reference point.
As the latest TRD available with v2015.4, does it mean the support for TRD will be not be available further? OR may be in near future it will be available? please advise
Thanks !
Shrikant
u4223374
Advisor
Advisor
shrikantb
Thanks for the details.
Shrikant
htsvn
hi,
the latest version of TRD that is available on the web is for 2015.4.
this is available in the link https://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation and is available when you use the most recent documents drop-down.
--hs
shrikantb
hi,
Thanks for the details, regarding the latest TRD 2015.4 got the info as well in second comment of this thread.
was more curious for updated tag like v2016.2.
Shrikant
