06-18-2017 01:42 AM
HI all,
I was tryng to run Lab_1 (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug948-vivado-sysgen-tutorial.pdf) of System Generator for DSP on Vivado 2016.1 and R2015b MatLab combination. I'm getting below error and could not find a way to solve this. I'm starting the system generator as suggested in http://www.xilinx.com/support/answers/41563.html. I have generated env.txt file and uploaded below.
Could somebody have a look at this kindly.
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2016.1 C:/Xilinx/Vivado/2016.1
Matlab 8.6.0.267246 (R2015b) C:\Program Files\MATLAB\R2015b
Vivado 2016.1 C:/Xilinx/Vivado/2016.1
Summary of Errors:
Error 0001: Sysgen license checkout failed.
XILINXD_LICENSE_FILE = C...
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
XILINXD_LICENSE_FILE = C:/Xilinx/Vivado/2016.1/data/sysgen/hwcosim_compiler/pp_ethernet
Environment variable LM_LICENSE_FILE is not set.
License search path: C:\.Xilinx;C:\Xilinx\Vivado\2016.1\data\sysgen\hwcosim_compiler\pp_ethernet;C:\Xilinx\Vivado\2016.1\data\ipcore_licenses
Namalka
06-18-2017 03:55 AM - edited 06-18-2017 04:03 AM
Hi @nliyanage@90,
Sysgen needs Sytem edition License, If you already have a valid license then can you please set the XILINXD_LICENSE_FILE to the location of license file.
Follow the below steps:
1. Open Xilinx License Configuration Manager.
2. Click on Manage License search path tab.
3. Set the XILINXD_LICENSE_FILE: C:\location\of\license\file\Xilinx.lic
4. Click on Set.
If this does not help, please attach the license file for further analysis. If you do not have a license. As from the attached env.txt I see the IP core licenses information only.
Note: if you just trying to practice and test the labs. You can just opt fora 30 day evaluation license that covers sysgen tool .
refer: https://www.xilinx.com/products/design-tools/vivado.html#buy
Sravanthi B
Hi @nliyanage@90,
4. Click on Set.
Sravanthi B
06-18-2017 09:56 PM
06-18-2017 10:32 PM
Hi nliyanage@90,
I only see the IP licenses in the env report generated. Try installing the tool license first to bypass this error.
Prathik
Helpful answer -> Give Kudos
06-19-2017 12:31 AM
Thank you so much, it was an error with the settings of license server.
06-19-2017 12:43 AM - edited 06-19-2017 12:44 AM
Hi nliyanage@90,
Can you please mark the post which helped to resolve your query, as an answer "Accept as solution" and close this thread. This will help other users in future with the same query.
Sravanthi B
06-19-2017 01:11 AM
Hi nliyanage@90,
["error with the settings of license server"]
Can you please elaborate how the issue got resolved? What was the cause?
Thanks a lot !
Prathik
06-19-2017 05:34 PM
My licence server was not set in my PC. When I fixed that this issue was resolved.
Thanks all.
06-19-2017 09:31 PM
Hi nliyanage@90,
Thank you so much for letting us know the cause for this issue.
Prathik
09-03-2017 05:01 AM
I'm also facing the same issue like this.
Version Path
System Generator 2015.2 C:/Xilinx/Vivado/2015.2
Matlab 8.4.0.150421 (R2014b) C:\Program Files\MATLAB\R2014b
Vivado 2015.2 C:/Xilinx/Vivado/2015.2
Summary of Errors:
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
XILINXD_LICENSE_FILE = C:/Xilinx/Xilinx.lic;C:/Xilinx/Vivado/2015.2/data/sysgen/hwcosim_compiler/pp_ethernet
LM_LICENSE_FILE = C:/Xilinx/Xilinx.lic
License search path: H:\.Xilinx;C:\Xilinx\Xilinx.lic;C:\Xilinx\Vivado\2015.2\data\sysgen\hwcosim_compiler\pp_ethernet;C:\Xilinx\Xilinx.lic;C:\Xilinx\Vivado\2015.2\data\ipcore_licenses
Also when i check the license manager,under the host id match column, its written as 'No' eventhough i have purchased the license. Could you help me with this?
09-03-2017 09:22 AM
Hi @jerry160990,
Can you please create a new thread and share the xinfo.txt and license file.
Run the below Tcl command in vivado Tcl console to generate xinfo.txt :
report_environment -file xinfo.txt
Which OS are you working upon?
As you mentioned that while you checked the license manager, under the host id match column its written as 'No' then can you please try regenerating/rehosting the license with the required hostid and check if that helps.
Thanks & Regards,
Sravanthi B
