kumarkk
Error Microblaze server implemntation NExys 4 DDR
Hello all,
 I'm trying to implement Microblaze server on Nexys 4 DDR. Design steps are provide on official website, i follow same procedure as mention on website but while generating Bitstream following error pop up and synthesis failed. please suggest possible errors in design and modification to be done to block diagram.
I have attach snap of error message and Block diagram below.
PFA,
Thanks in Advance
Kumar Khandagle.
balkris
As mentioned in AR http://www.xilinx.com/support/answers/53920.html you can drive IBUFDS_GTE2 output to BUFG/BUFH which can then drive MMCM.
Thanks and Regards
Balkrishan
