Error in output declaration
Hi.,
        I wrote a program to read the memory from single port ram as
module txete(clka,wea,addra,dina,douta );
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output [7:0]douta;
ramq r1(clka,wea,addra,dina,douta);
reg [7:0] rom1 [16383:0];
reg [13:0]addra_reg;
initial
$readmemh("inputHexp.txt", rom1, 0,16383);
always @ (posedge clka)
begin
// Write
if (wea)
addra_reg <= addra;
rom1[addra_reg] <= dina;
assign douta = rom1[addra_reg];
end
endmodule
but it shows error as:
ERROR:HDLCompilers:247 - "txete.v" line 22 Reference to vector wire 'douta' is not a legal reg or variable lvalue
ERROR:HDLCompilers:42 - "txete.v" line 22 Illegal left hand side of procedural assign
help me to clear this error...
Re: Error in output declaration
These errors occur if signals declared as wire type are assigned a value using an always block statement.
If a conditional assignment is needed, you must use a reg data type.
Modify your code as below:
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output reg [7:0]douta;
initial
begin // Write
if (wea)
addra_reg <= addra;
end
endmodule
thanks but it again shows error as:
ERROR:HDLCompilers:246 - "txete.v" line 7 Reference to vector reg 'douta' is not a legal net lvalue
ERROR:HDLCompilers:102 - "txete.v" line 7 Connection to output port 'douta' must be a net lvalue
ERROR:HDLCompilers:246 - "txete.v" line 19 Reference to vector reg 'douta' is not a legal net lvalue
ERROR:HDLCompilers:102 - "txete.v" line 19 Connection to output port 'douta' must be a net lvalue
For continuous assignments, you must use wire data type.
So change the code as follows:
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output [7:0]douta;
reg [7:0] douta1;
initial
begin // Write
if (wea)
addra_reg <= addra;
douta1 <= rom1[addra_reg];
end
assign douta = douta1;
endmodule
you need to move assign douta line out of the always block, put it after "end" and before endmodule. That should fix your problem. But you have another issue: you are connecting douta to both ramq and using it as output of rom1. I am not sure what ramq does but it sure looks like douta is being used as output. This will create a conflict.
hi
im trying to put something on LCD using verilog. 1234.... for now
im using the clock and then instenciating a divider module to slow it down
but im also getting the same error as above has been stated...
this is my main program:
module display_numbers_timer_divide(SW_0,clk, sf_ce0, lcd_rs, lcd_rw, lcd_e, lcd_4, lcd_5, lcd_6, lcd_7);
                             parameter k=18;
(* LOC="L13"*) input SW_0;
(* LOC="C9" *) input clk; // synthesis attribute PERIOD clk "50 MHz"
                             reg [7:0]count=0;
(* LOC="D16" *) output reg sf_ce0; // high for full LCD access
                             reg lcd_busy=1;
                               reg lcd_stb;
                              reg [5:0]lcd_code;
                              reg [6:0]lcd_stuff
                             reg clk_1;
                            reg clk_2;
                               reg clk_3;
(* LOC="L18" *) output reg lcd_rs;
(* LOC="L17" *) output reg lcd_rw;
(* LOC="M15" *) output reg lcd_7;
(* LOC="P17" *) output reg lcd_6;
(* LOC="R16" *) output reg lcd_5;
(* LOC="R15" *) output reg lcd_4;
(* LOC="M18" *) output reg lcd_e;
divider d1 (clk,clk_1);
divider d2 (clk_1,clk_2);
divider d3 (clk_2,clk_3);
always @ (posedge clk_3 )
begin
count <= count + 1;
end
always @ (posedge clk)
begin
sf_ce0 <= 1;
case(count[7:2])
0:lcd_code <= 6'h03; // power-on initialization
1:lcd_code <= 6'h03;
2:lcd_code <= 6'h03;
3:lcd_code <= 6'h02;
4:lcd_code <= 6'h02; // function set
5:lcd_code <= 6'h08;
6:lcd_code <= 6'h00; // entry mode set
7:lcd_code <= 6'h06;
8:lcd_code <= 6'h00; // display on/off control
9:lcd_code <= 6'h0C;
10:lcd_code <= 6'h00; // display clear
11:lcd_code <= 6'h01;
12: lcd_code <= 6'h23; //1
13: lcd_code <= 6'h21;
14: lcd_code <= 6'h23; //2
15: lcd_code <= 6'h22;
16: lcd_code <= 6'h23; //3
17: lcd_code <= 6'h23;
18: lcd_code <= 6'h23; //4
19: lcd_code <= 6'h24;
20: lcd_code <= 6'h23; //5
21: lcd_code <= 6'h25;
22: lcd_code <= 6'h23; //6
23: lcd_code <= 6'h26;
24: lcd_code <= 6'h23; //7
25: lcd_code <= 6'h27;
26: lcd_code <= 6'h23; //8
27: lcd_code <= 6'h28;
28: lcd_code <= 6'h23; //9
30: lcd_code <= 6'h29;
endcase
// if(i<82000) //adding delay
// i<=i+1;
if (lcd_rw) // comment-out for repeating display
lcd_busy <= 0; // comment-out for repeating display
lcd_stb <= ^count[1:0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2)
lcd_stuff <= {lcd_stb,lcd_code};
{lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff;
end
endmodule
and this is my divider program:
module divider(Clk_in, Clk_out);
// input ports
input Clk_in;
// output ports
output reg Clk_out = 1'b0; // provide initial condition for this register.
// counter size calculation according to input and output frequencies
parameter sys_clk = 50000000; // 50 MHz system clock
parameter clk_out = 1000000; // 1 MHz clock output
parameter max = sys_clk / (2*clk_out); // max-counter size
reg [4:0]counter = 0; // 5-bit counter size
always@(posedge Clk_in) begin
if (counter == max-1)
begin
counter <= 0;
Clk_out <= ~Clk_out;
end
else
begin
counter <= counter + 1'd1;
end
end
endmodule
the error that i get when i simulate my main program is:
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 45 Reference to scalar reg 'clk_1' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 45 Connection to output port 'Clk_out' must be a net lvalue
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 46 Reference to scalar reg 'clk_2' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 46 Connection to output port 'Clk_out' must be a net lvalue
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 47 Reference to scalar reg 'clk_3' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 47 Connection to output port 'Clk_out' must be a net lvalue
You need to declare clk_1, clk_2 and clk_3 as wire instead of reg. Also in module divider you have a port named Clk_out and a parameter named clk_out. It is very error prone to depend on the case sensitivity of Verilog. I suggest that you rename the clk_out parameter so something like clk_out_scaler.
