Error in output declaration
Hi.,
        I wrote a program to read the memory from single port ram as
module txete(clka,wea,addra,dina,douta );
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output [7:0]douta;
ramq r1(clka,wea,addra,dina,douta);
reg [7:0] rom1 [16383:0];
reg [13:0]addra_reg;
initial
$readmemh("inputHexp.txt", rom1, 0,16383);
always @ (posedge clka)
begin
// Write
if (wea)
addra_reg <= addra;
rom1[addra_reg] <= dina;
assign douta = rom1[addra_reg];
end
endmodule
but it shows error as:
ERROR:HDLCompilers:247 - "txete.v" line 22 Reference to vector wire 'douta' is not a legal reg or variable lvalue
ERROR:HDLCompilers:42 - "txete.v" line 22 Illegal left hand side of procedural assign
help me to clear this error...
Re: Error in output declaration
These errors occur if signals declared as wire type are assigned a value using an always block statement.
If a conditional assignment is needed, you must use a reg data type.
Modify your code as below:
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output reg [7:0]douta;
initial
begin // Write
if (wea)
addra_reg <= addra;
end
endmodule
thanks but it again shows error as:
ERROR:HDLCompilers:246 - "txete.v" line 7 Reference to vector reg 'douta' is not a legal net lvalue
ERROR:HDLCompilers:102 - "txete.v" line 7 Connection to output port 'douta' must be a net lvalue
ERROR:HDLCompilers:246 - "txete.v" line 19 Reference to vector reg 'douta' is not a legal net lvalue
ERROR:HDLCompilers:102 - "txete.v" line 19 Connection to output port 'douta' must be a net lvalue
For continuous assignments, you must use wire data type.
So change the code as follows:
input clka;
input wea;
input [13:0]addra;
input [7:0] dina;
output [7:0]douta;
reg [7:0] douta1;
initial
begin // Write
if (wea)
addra_reg <= addra;
douta1 <= rom1[addra_reg];
end
assign douta = douta1;
endmodule
Teacher muzaffer
you need to move assign douta line out of the always block, put it after "end" and before endmodule. That should fix your problem. But you have another issue: you are connecting douta to both ramq and using it as output of rom1. I am not sure what ramq does but it sure looks like douta is being used as output. This will create a conflict.
hi
im trying to put something on LCD using verilog. 1234.... for now
im using the clock and then instenciating a divider module to slow it down
but im also getting the same error as above has been stated...
this is my main program:
module display_numbers_timer_divide(SW_0,clk, sf_ce0, lcd_rs, lcd_rw, lcd_e, lcd_4, lcd_5, lcd_6, lcd_7);
                             parameter k=18;
(* LOC="L13"*) input SW_0;
(* LOC="C9" *) input clk; // synthesis attribute PERIOD clk "50 MHz"
                             reg [7:0]count=0;
(* LOC="D16" *) output reg sf_ce0; // high for full LCD access
                             reg lcd_busy=1;
                               reg lcd_stb;
                              reg [5:0]lcd_code;
                              reg [6:0]lcd_stuff
                             reg clk_1;
                            reg clk_2;
                               reg clk_3;
(* LOC="L18" *) output reg lcd_rs;
(* LOC="L17" *) output reg lcd_rw;
(* LOC="M15" *) output reg lcd_7;
(* LOC="P17" *) output reg lcd_6;
(* LOC="R16" *) output reg lcd_5;
(* LOC="R15" *) output reg lcd_4;
(* LOC="M18" *) output reg lcd_e;
divider d1 (clk,clk_1);
divider d2 (clk_1,clk_2);
divider d3 (clk_2,clk_3);
always @ (posedge clk_3 )
begin
count <= count + 1;
end
always @ (posedge clk)
begin
sf_ce0 <= 1;
case(count[7:2])
0:lcd_code <= 6'h03; // power-on initialization
1:lcd_code <= 6'h03;
2:lcd_code <= 6'h03;
3:lcd_code <= 6'h02;
4:lcd_code <= 6'h02; // function set
5:lcd_code <= 6'h08;
6:lcd_code <= 6'h00; // entry mode set
7:lcd_code <= 6'h06;
8:lcd_code <= 6'h00; // display on/off control
9:lcd_code <= 6'h0C;
10:lcd_code <= 6'h00; // display clear
11:lcd_code <= 6'h01;
12: lcd_code <= 6'h23; //1
13: lcd_code <= 6'h21;
14: lcd_code <= 6'h23; //2
15: lcd_code <= 6'h22;
16: lcd_code <= 6'h23; //3
17: lcd_code <= 6'h23;
18: lcd_code <= 6'h23; //4
19: lcd_code <= 6'h24;
20: lcd_code <= 6'h23; //5
21: lcd_code <= 6'h25;
22: lcd_code <= 6'h23; //6
23: lcd_code <= 6'h26;
24: lcd_code <= 6'h23; //7
25: lcd_code <= 6'h27;
26: lcd_code <= 6'h23; //8
27: lcd_code <= 6'h28;
28: lcd_code <= 6'h23; //9
30: lcd_code <= 6'h29;
endcase
// if(i<82000) //adding delay
// i<=i+1;
if (lcd_rw) // comment-out for repeating display
lcd_busy <= 0; // comment-out for repeating display
lcd_stb <= ^count[1:0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2)
lcd_stuff <= {lcd_stb,lcd_code};
{lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff;
end
endmodule
and this is my divider program:
module divider(Clk_in, Clk_out);
// input ports
input Clk_in;
// output ports
output reg Clk_out = 1'b0; // provide initial condition for this register.
// counter size calculation according to input and output frequencies
parameter sys_clk = 50000000; // 50 MHz system clock
parameter clk_out = 1000000; // 1 MHz clock output
parameter max = sys_clk / (2*clk_out); // max-counter size
reg [4:0]counter = 0; // 5-bit counter size
always@(posedge Clk_in) begin
if (counter == max-1)
begin
counter <= 0;
Clk_out <= ~Clk_out;
end
else
begin
counter <= counter + 1'd1;
end
end
endmodule
the error that i get when i simulate my main program is:
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 45 Reference to scalar reg 'clk_1' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 45 Connection to output port 'Clk_out' must be a net lvalue
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 46 Reference to scalar reg 'clk_2' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 46 Connection to output port 'Clk_out' must be a net lvalue
ERROR:HDLCompilers:246 - "display_numbers_timer_divide.v" line 47 Reference to scalar reg 'clk_3' is not a legal net lvalue
ERROR:HDLCompilers:102 - "display_numbers_timer_divide.v" line 47 Connection to output port 'Clk_out' must be a net lvalue
Teacher muzaffer
You need to declare clk_1, clk_2 and clk_3 as wire instead of reg. Also in module divider you have a port named Clk_out and a parameter named clk_out. It is very error prone to depend on the case sensitivity of Verilog. I suggest that you rename the clk_out parameter so something like clk_out_scaler.
