Observer defrageliu
FreeRTOS interrupt does not work
  I meet a problem when using the FreeRTOS with zynq. In SDK software, I connect the callback function the the XscuGic controller in the FreeRTOS and enable the interrupt. I use the ila in vivado to analyze the signal, it shows that the interrupt works well, but the FreeRTOS does nothing. That is ,when the OS call the FreeRTOS_ApplicationIRQHandler function only with the interrupt id 29(it is seem to be the interrupt id with the timer). However, no any other interrupt id, i prefer to, I get in the FreeRTOS_ApplicationIRQHandler function.
  Is there any one can help me? Thank you~
Alvin Defrage.
Observer richardbarry
Re: FreeRTOS interrupt does not work
Have you read through how to install the handlers on the page that describes how to use FreeRTOS on Cortex-A processors?
Also, the Zynq demo in the FreeRTOS download and the FreeRTOS+TCP examples can be used as a reference.
Richard.
+ http://www.FreeRTOS.org
The de facto standard, downloaded every 4.2 minutes during 2015.
+ http://www.FreeRTOS.org/plus
IoT, Trace, Certification, TCP/IP, FAT FS, Training, and more...
Richard.
Observer defrageliu
Hello Richard,
    Yes, I have already read the documents, even followed the demo in the FreeRTOS resource. but it still doesn't work. I connect the interrupt signal from the axi quad spi ip core to the zynq irq_f2p interface. By the way, I just use the freertos bsp which is generated by the SDK automatically. Is there something wrong with the BSP, or  I use it in wrong way?
Thank you very much
Best wishes,
Defrage
Observer defrageliu
Hello @richardbarry
Thank you very much~, Just after reading the demo carefully, I find the problem. Now the interrupt works well.
Defrage
