dmitryl_home
How to change username without loosing the whole profile?
Hi All,
Is it possible to change the displayed name in this forum? how?
Is it possible to change a username while keeping all the rest the profile attributes (subscriptions, bookmarks, etc)?
Thank you!
florentw
Hi @dmitryl_home,
I guess you have found the response but I just want to have it here also. The response is mentioned in:
https://forums.xilinx.com/t5/Announcements/Change-user-name-ID/td-p/355173
Best Regards,
Florent
Florent
florentw
Hi @dmitryl_home,
Best Regards,
Florent
Florent
robforester
I also would like to know about this. Please let me know how can I change my username.
florentw
Hi @robforester,
Why didn't you follow the link I gave...
We are unable to change your Community Forums User ID due to our Single sign-On (SSO), which is a session and user authentication service that permits a user to use one set of login credentials (e.g., name and password) to access multiple applications and other areas Xilinx.
Additionally, it is not possible to completely delete a member from the community in a literal sense. This is due to the fact that removing an account would cause holes in conversations as well as other gaps in data.
Option 1
Request your existing Xilinx account to be deleted by filling out the Website Feedback form. After your account has been deleted, create a new Xilinx account, and then request that this ID is associated to your existing forum account by emailing forumadmin@xilinx.com, so that none of your forum history is lost.
Note: All the Licenses, and other details including your Community Forums account are linked to your Xilinx account. Once the account is deleted, you will not have access.
Or
Option 2
Create a second Xilinx.com account and request that this ID is associated to your existing forum account by emailing forumadmin@xilinx.com.
Florent
robforester
Right! I missed the link. Thanks for the reminder.
