ian_apical
How to close/remove an account
I have generated a second account in order to be able to recreate a problem that users at our company were having generating accounts on xilinx.com. This account has now served its purpose, how can I arrange for its closure/deletion.
Similarly I would like to now the process for requestion the closure / suspension of accounts belonging to ex-employees.
Thank you in anticipation.
syedz
Hello @ian_apical,
Please fill out the Website Feedback form. Check the below similar thread:
https://forums.xilinx.com/t5/New-Users-Forum/Delete-Xilinx-account-possible/td-p/476704
--Syed
syedz
Hello @ian_apical,
--Syed
syedz
Hello @ian_apical,
Did the above suggestion helped?
--Syed
ian_apical
I did get a reply thanks. I assume the account in question has been removed as I haven't tested this yet
