How to deselect XST option ISE 12.4 and synthesize
Hello I want to deselect XST option in ISE 12.4 as I am getting an error about port 1 of <inst_name> is connected to GND.
jeevanreddymandali
Check in RTL how the inputs and outputs of this BUFG "init_clk_ibufg_i" are connected.
Deepika.
Deepika.
Can you copy paste the complete error message?
Which XST option do you want to disable?
Deepika.
Deepika.
Port 1 of <inst_name> is connected to GND
>> Can be a valid error or warning, it generally arises when your deisgn has some signals/ports that have no transitions.
For example if you you declare a 7 bit counter and run it only till 32 only 5 bits will be used the rest will be always stuck to ground.
You should check if the error is valid for your design in which case you can ignore it .
Deselecting XST might not be an option to resolve it
Hope this helps
Vanitha.
Okay, this is the actual error. I donot know which XST option I want to deselect. While I was trying searching this error in google I got an answer suggesting me to turn off the XST and synthesize, So, I started giving it a try.
Mapping all equations...
ERROR:Xst:2033 - Port I of Input buffer Inst_aurora1/reset_logic_i/init_clk_ibufg_i is connected to GND
ERROR:Xst:2033 - Port I of Input buffer Inst_aurora2/reset_logic_i/init_clk_ibufg_i is connected to GND
ERROR:Xst:1847 - Design checking failed
Process "Synthesize - XST" failed
jeevanreddymandali
Check if you are using a BUFIO external to the core as there will be a BUFIO
already in the core, which causes this error.
To resolve this problem, remove the BUFIO instantiation outside the core.
Satish
Deepika.
Deepika.
As discussed in the other thread http://forums.xilinx.com/t5/Virtex-Family-FPGAs/How-to-create-a-black-box-NGC-file-by-writing-a-module-that/m-p/388163#M17973 , this issue is due to buffer in top level driving IBUFG in the core. You need to either remove the IBUFG inside the core or directly connect it to port in top level.
Deepika.
Deepika.
