How to get random bit sequence in XSDK from HLS IP
Currently I'm working with Kintex 7, for random bit sequence function. I have created HLS IP for the function, integrated IP with vivado and exported it to SDK.
But in SDK, i am getting only "Single bit" value instead of sequence of random bits. I think its showing last bit of sequence in Hardware. Please anyone guide me. What`s wrong in my coding? Need help from anyone.
Hls Source code
#include <stdint.h>
#include <stdio.h>
#include "ap_cint.h"
int PRBS_prj()
#pragma HLS INTERFACE s_axilite port=return bundle=a
   int start_state = 0xCD;
   int lfsr = start_state;
   bool bit;
    unsigned period = 0;
do
    /* taps:  3, 2 and 1 ; feedback polynomial:  x^3 + x^2 + 1 */
    bit = ((lfsr >> 0) ^ (lfsr >> 2) ^ (lfsr >> 3) ^ (lfsr >> 4) ) & 1;
    printf("%d", bit);
    lfsr = (lfsr >> 1) | (bit << 7);
            ++period;
        } while (lfsr != start_state);
return bit;
Test Bench
#include <stdint.h>
#include <stdio.h>
int main()
   bool bit;
    PRBS_prj();
    do
        printf("%d", bit);
                ++period;
return 0;
SDK Source Code
#include "xprbs_prj.h"
int main()
    init_platform();
     bool Resulth;
  xil_printf("%c[2J",27);
  XPrbs_prj PRBS;
  XPrbs_prj  *PRBSPTR=&PRBS;
  XPrbs_prj_Initialize(PRBSPTR,XPAR_PRBS_PRJ_0_DEVICE_ID);
  XPrbs_prj_Start(PRBSPTR);
   while (!XPrbs_prj_IsDone(PRBSPTR));
   Resulth=XPrbs_prj_Get_return(PRBSPTR);
   xil_printf("[hw] Resulth = %d \r\n", Resulth);
   cleanup_platform();
  return 0;
************************** Function Prototypes *****************************/
#ifndef __linux__
int XPrbs_prj_Initialize(XPrbs_prj *InstancePtr, u16 DeviceId);
XPrbs_prj_Config* XPrbs_prj_LookupConfig(u16 DeviceId);
int XPrbs_prj_CfgInitialize(XPrbs_prj *InstancePtr, XPrbs_prj_Config *ConfigPtr);
#else
int XPrbs_prj_Initialize(XPrbs_prj *InstancePtr, const char* InstanceName);
int XPrbs_prj_Release(XPrbs_prj *InstancePtr);
#endif
void XPrbs_prj_Start(XPrbs_prj *InstancePtr);
u32 XPrbs_prj_IsDone(XPrbs_prj *InstancePtr);
u32 XPrbs_prj_IsIdle(XPrbs_prj *InstancePtr);
u32 XPrbs_prj_IsReady(XPrbs_prj *InstancePtr);
void XPrbs_prj_EnableAutoRestart(XPrbs_prj *InstancePtr);
void XPrbs_prj_DisableAutoRestart(XPrbs_prj *InstancePtr);
u32 XPrbs_prj_Get_return(XPrbs_prj *InstancePtr);
void XPrbs_prj_InterruptGlobalEnable(XPrbs_prj *InstancePtr);
void XPrbs_prj_InterruptGlobalDisable(XPrbs_prj *InstancePtr);
void XPrbs_prj_InterruptEnable(XPrbs_prj *InstancePtr, u32 Mask);
void XPrbs_prj_InterruptDisable(XPrbs_prj *InstancePtr, u32 Mask);
void XPrbs_prj_InterruptClear(XPrbs_prj *InstancePtr, u32 Mask);
u32 XPrbs_prj_InterruptGetEnabled(XPrbs_prj *InstancePtr);
u32 XPrbs_prj_InterruptGetStatus(XPrbs_prj *InstancePtr);
#ifdef __cplusplus
#endif
Tags (2)
Re: How to get random bit sequence in XSDK from HLS IP
Oops, finally i have got random bit sequences in XSDK from HLS IP. Just, i have used register concept for writing program for PRBS function in HLS.
@thaus_015 the problem is that your hls accelerated block always runs the whole sequence (because of the do while loop) and it returns the last "bit". If you want to be able to call it repeatedly and get a different bit of the lfsr sequence, you need to define the "lfsr" variable as static and do only one step of the lfsr update each time it's called. So get rid of the do while loop in PRBS_prj, declare lfsr as static and update lfsr just once per call of the accelerated function.
To muzaffer, Still, my problem is not solved. Still i am facing same problem. Please help me out in completing this task. Did some modification in source code of HLS but still getting last bit in TERA TERAMINAL.
Suggest me :)
Source code:
int PRBS_prj()
    static unsigned lfsr  = 0xCD;
       int bit, i;
       for ( i = 0; i < 50; i++)
     printf("%d", bit);
       return bit;
Test Beach
int main()
   int bit, i;
    PRBS_prj();
  printf("%d", bit);
return 0;
@thaus_015 you still have a loop in PRBS_prj where you have replaced the do, while with a for loop. You should get rid of the loop, have it execute only one stage of the lfsr update each time it's called. I am assuming this is what you want to accomplish.
Also in the main, you are not checking the return of the function at all. You should put the PRBS_prj and the local calculation in a loop and compare the results for every bit output from the main lfsr & also from the PRBS_prj function.
@muzaffer, I have changed my programming codes without loop. But, eventhough i am not getting random Sequence in XSDK. I am struggling with this task. Please tell me the way, how to getting random sequences in XSDK through HLS IP.
HLS Source code:
int main(void)
    static int lfsr = 0x3425u;
    unsigned int mask = 0xF0;
    int bit;                    /* Must be 16bit to allow bit<<15 later in the code */
        //taps: 16 14 13 11; feedback polynomial: x^16 + x^14 + x^13 + x^11 + 1
        bit  = ((lfsr >> 0) ^ (lfsr >> 2) ^ (lfsr >> 3) ^ (lfsr >> 5) ) & 1;
        lfsr =  (lfsr >> 1) | (bit << 15);
        for (mask = 0xF0; mask; mask >>= 1)
        putchar('0' + !!(lfsr & mask));
    return lfsr;
@thaus_015 main is your testbench (right?)  and the PRBS_prj is the HLS accelerated function. In main,  you need the loop which calls the local test lfsr and you need to include PRBS_prj in this loop. PRBS_prj should generate one bit output at a time and in the main loop, you need to compare PRBS_prj output to the local lfsr. PRBS_prj should not have a loop in it. It should have static on lfsr and shift once and produce one bit of output everytime it is called (assuming this is what you are trying to accomplish)
@muzaffer. I have tried but i am not getting sequences of bit from HLS IP.
I think that to get non-stop stream of random bits out of the IP, then one way is using FIFO for connecting the IP to PS and hls::stream at the output of the HLS code. For steam data communication between an IP and SDK, i am right ?
I am also facing the same problem from several days..Can you explain me what is register concept in HLS..so that we will get continuous values in SDK.
Can you explain your concept. Actually, what you need as output.
HI @manoj_king,
Please create a new topic on the Vivado HLS board a this topic is quite old and close. You can tag thaus_15 if needed using the @ + username.
Florent
