maheshjv
How to implement Fixed pattern noise removal(image processing) in FPGA
Need Information how to implement fixed pattern noise core in the FPGA?
Can anyone help on the above issue.
balkris
use image reduction IP from Xilinx
http://www.xilinx.com/products/intellectual-property/ef-di-img-noise.html
Thanks and Regards
Balkrishan
maheshjv
Hello Bala,
Thank for you post .
But they is no mentioning of Fixed pattern noise in the Image noise reduction doucment(Presently moved to Image enhancement core).
Are you sure of that this core removes fixed patern noise.
And also i have one more query xilinx have discontinued the defect pixel correction.
I need a core for defect pixel correction and hotspot removal can you help me on these ?????
Please reply as soon as possible
balkris
defect pixel correction was discontinue as you aware
http://www.xilinx.com/support/answers/54521.html
Thanks and Regards
Balkrishan
