sophia_123
How to open the wave file generated by vivado
I saved a .wcfg file but don't konw how to open it.Can someone please help me?
Sophia
syedz
@sophia_123,
https://www.xilinx.com/support/answers/64116.html
Also check page number 76 in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug900-vivado-logic-simulation.pdf
--Syed
syedz
@sophia_123,
--Syed
arpansur
Hi @sophia_123,
Do you have WDB file? Please go through https://www.xilinx.com/support/answers/60365.html
Please go through page-76 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug900-vivado-logic-simulation.pdf
Arpan
