Observer lior_glass
IP Integrator systemverilog interface support
I'd like to extract several AXI4 ports out from the IP Integrator and it is a lot of signals.
So I think to add a user IP to the IP Integrator which will wrap the the AXI4 bus into a signal systemverilog interface.
Does the IP Integrator support systemverilog interface?
Lior Glass
Teacher muzaffer
Re: IP Integrator systemverilog interface support
This is something I suggested a long time ago. I even gave them my basic implementation of an axi interface for them to use ;-)
They should add a systemverilog option to the languages and generate code which uses interfaces where needed.
Right now, I wrap all Xilinx generated AXI IP with my axi interface wrapper. It's not that bad but I hate to introduce a completely unnecessary hierarchy layer just for some syntactic sugar (albeit tasty).
Teacher muzaffer
Scholar markcurry
We do the exact same thing muzaffer.  We've even wrapped the axi_interconnect.  A lot of duplicated work.  Here's hoping Xilinx starts doing this on their own.
Mark
Participant egrigor
Yes, this is sorely needed. It's interesting that the IP Integrator GUI takes heavy advantage of interfaces to facilitate the design process, but yet when it comes time for the tool to genrate the Verilog code, it's stuck in the old Verilog standard. Supporting SV output code generation would be a far superior and cleaner approach. Xilinx, please add this capability right away.
