Participant vazquez
Kintex GT - Reference clock routing to adjacent QUADs fails in placemet
Hi newsgroup,
on a Kintex-7 design I am getting the following error message in Vivado 2015.1:
[Place 30-512] Clock region assignment has failed. Clock buffer 'g_CAT_GTRefclks[0].i_ibufds' (IBUFDS_GTE2) is placed at site IBUFDS_GTE2_X0Y8 in CLOCKREGION_X1Y4. Its loads need to be placed in the area enclosed by clock regions CLOCKREGION_X1Y4 and CLOCKREGION_X1Y4. One of its loads 'g_CAT.i_qfab/g_Quads[7].i_quad/U0/transceiver_inst/gtwizard_inst/U0/GTWIZARD_i/gt0_GTWIZARD_i/gtxe2_i' (GTXE2_CHANNEL) is placed in site GTXE2_CHANNEL_X0Y12 in CLOCKREGION_X1Y3 which is outside the permissible area.
I have found AR#60258
http://www.xilinx.com/support/answers/60258.html
It is said to be a known issue and to be resolved in 2014.2.
Has this issue only been fixed for Artix-7 devices?
Rgds, vazquez
Re: Kintex GT - Reference clock routing to adjacent QUADs fails in placemet
Hi @vazquez
I see that the IBUFDS_GTE2 is driving the TXUSRCLK and TXUSRCLK2 pins of the GT_CHANNEL instances directly. In general it is recommended to drive these pins from BUFG to have minimal skew between them.
Refer to page-109 "TXUSRCLK and TXUSRCLK2 generation" of http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Deepika.
Deepika.
Hi @vazquez
How many GT instances is this IBUFDS_GTE2 instance driving? Are they within 3 adjacent clock regions?
Can you attach the _opt.dcp located at .runs-->impl_1 folder?
Deepika.
Deepika.
Participant vazquez
The IBFUDS_GTE2 instance is driving 19 other GT instances (total of 20 QSGMII-IP-Core instances).
Hi @vazquez
These rules must be observed when sharing a reference clock to ensure that jitter margins for high-speed designs are met:
• The number of Quads above the sourcing Quad must not exceed one.
• The number of Quads below the sourcing Quad must not exceed one.
• The total number of Quads sourced by an external clock pin pair (MGTREFCLKN/ MGTREFCLKP) must not exceed three Quads (or 12 transceivers).
It looks like you are not following 3rd point above. Please modify your design to satisfy this requirement.
Deepika.
Deepika.
Participant vazquez
I am connecting an external clock pin pair (MGTREFCLKN/ MGTREFCLKP) to an IBUFDS_GTE2. The output of that I connect
to a BUFG to drive all the GMII-TX-Interfaces of the 20 QSGMII-IP-Cores.
The GTRefClk-Inputs of 4 QSGMII-IP-Cores are driven by one clock pin pair (MGTREFCLKN/ MGTREFCLKP). So there is a total number of 5 clock pin pairs (MGTREFCLKN/ MGTREFCLKP) to drive 20 QSGMII GTRefClks. And clock pin pair number 0 is driving (by BUFG as stated above) all GMII-TX-Interfaces (to have exactly one tx user clock in my design). The 5 external clocks are distributed by an external clock distribution chip.
In "ug472_7Series_Clocking.pdf" the following statement can be found:
"BUFGs do not belong to a clock region and can reach any clocking point on the device."
So does the restriction No.3 you mentioned apply to my design?
Regards, vazquez
Hi @vazquez
As per my knowledge the MGTREFCLK pins of GT instances should be directly driven by IBUFDS_GTE2 primitive (you can drive it from BUFG).
Can you attach the _opt.dcp file?
Deepika.
Deepika.
Participant vazquez
No, only the GMII-TX interfaces are driven by MGTREFCLK(0) -> IBUFDS_GETES -> BUFG
The .dcp file has 16MB.
Participant vazquez
Hi @vazquez
I will send you ezmove package where you can upload the DCP file.
Deepika.
Deepika.
Hi @vazquez
Deepika.
Deepika.
Participant vazquez
Thank you very much. Although drawn the BUFG connection in my diagram I had not made the correct BUFG connection in my HDL code.
