dlerhasan
My first question on this forum - Zynq Board
We have recieved a task where we will control the engine performance through a tablet. My question is, why do they prefer the Zynq board? Is there any machines/products out there in the marked that uses the Zynq board?
aher
hi,
you can find applications of zinq in following links
http://www.xilinx.com/applications/automotive/multi-camera-adas.html
http://www.xilinx.com/applications/aerospace-and-defense/situational-awareness.html
also you can find its features in brief in following link and why is it more preferable
http://www.xilinx.com/products/silicon-devices/soc/zynq-7000.html
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
dlerhasan
Well that was a fast answer.
Thank you so much, I will take a look at the links you have requested.
anusheel
Zynq  devices combines the software programmability of a Processor with the hardware programmability of an FPGA. Refer below link for more details:
http://www.xilinx.com/products/silicon-devices/soc/zynq-7000.html#806738532001
Anusheel
Helpful answer -> Give Kudos
dlerhasan
Thank you for the answer :)
