Need alternate xilinx CPLD part for lattice semiconductor part(part#: ispLSI2064A)
Please suggest a alternate Xilinx CPLD part for Lattice semi part(part: ispLSI2064A)
thanks
Instructor
Instructor
Re: Need alternate xilinx CPLD part for lattice semiconductor part(part#: ispLSI2064A)
Suggest you 'shop' for yourself on the Xilinx website.  There is plenty of information describing each of the Xilinx CPLD families.  If you download and install Document Navigator, locating the various document will be simpler.
For most current software and device families, Xilinx provides a software tool for finding and accessing useful documents.  This tool is called DocNav, it installs on your PC, and you can download it with this .ZIP file link.
The problem with dropping a Lattice datasheet and asking for something similar is this:  there are probably some features and aspects of the Lattice devices which are useless to you, and some which are quite important.  Which are these?  This is important information.
For example:  I ask you for a Toyota automobile just like a Honda Civic.  Should you ignore any Toyota models which don't have the same paint colour options as the Honda Civic?  Should I ignore any Toyota models which don't have the same length?  Is a same-or-shorter model prefered because it fits in my garage?  Or is a same-or-longer model prefered because it is roomy and comfortable?
It's safe to say there is no exact match between Lattice and Xilinx.  So compare and shop based on the features and capabilities which are important to you, for your designs.
-- Bob Elkind
SIGNATURE:
Summary:
Thanks Bob for your support.
Yes, i searched xilinx parts and chosen XC95144XL CPLD part(3.3V supply part).
The issue is lattice part is 5V supply part and in xilinx, most of the 5V CPLD supply parts are obselete.
Prashant
> The issue is Lattice part is 5V supply part and in Xilinx, most of the 5V supply CPLD parts are obsolete.
So, why not stick with the Lattice part?
"If it don't work in simulation, it won't work on the board."
Instructor
Instructor
Are you saying that 5V input tolerance is important to your application?
Are you saying that 5V supply  (rather than 3.3V supply) is important to your application?
Are you saying that 5V output swings are important to your application?
-- Bob Elkind
SIGNATURE:
Summary:
Thanks BOB.
I need xilinx CPLD with 5V power supply pins(rather than 3.3V supply)....
Prashant
Instructor
Instructor
If you simply want to avoid a 3.3V supply, and you do not care about 5V signaling, then why not use a 3.3V device and drop the 5V supply to 3.3V with a LDO regulator or an NPN?
A quick search at digikey.com turns up SOT23.3 -size (tiny!) LDO 150mA regulator with 150mV dropout voltage for less than 12 cents in production volumes.  $0.12 is little enough additional cost for a 3.3V CPLD which has a number of years of production life.
A 200mA NPN plus a resistor divider might be even less expensive, but won't have short-circuit protection.
-- Bob Elkind
SIGNATURE:
Summary:
Historian
Historian
@prashant.hunagund wrote:
Thanks BOB.
Prashant
You haven't answered the question. Why not continue to use the Lattice part?
Dear bussman,
1. Lattice part is going to obselete.Did u open the datasheet which i attached earliler?
2. The price is high (10.2 USD) and customer wants BOM cost should be less than 90 USD.
The actual board schematic consists of 3 devices:
1. Lattice CPLD(The I/O's are 5V tolerent and VCC supply is 5V)
2. W5100 from Wiznet (The I/O's are 5V tolerent)
3. TNT4882 Single-Chip IEEE 488.2 Talker/Listener ASIC(The I/O's are 5V tolerent)
Since the I/O levels(TTL levels) of all devices are same there is no problem in communication between CPLD and other devices and same applies to XILINX CPLD also(because its I/O's are also 5V tolerent).
The issue is VCC supply voltage:
If i use xilinx part, then i need seperate LDO to generate 3.3V from 5V, which increase cost of the BOM.So i was searching xilinx part with 5V supply voltage and I/O's with 5V tolerent.
Another question is, how do calculate power requirement for xilinx  XC95144XL part, which is required to select LDO?
Please reply me ASAP.
thanks
Instructor
Instructor
Dear bussman Bassman,
2. W5100 from Wiznet (The I/O's are 5V tolerant)
According to the W5100 datasheet, it is a 3.3V device.  It requires both 3.3V and 1.8V power supplies (it has an internal 3.3V -> 1.8V regulator).  5V is not used.
TNT4882 is a 5V device.
It seems your customer's board already has a 3.3V supply, for the W5100 device.  The W5100 maximum current consumption is specified at around 180mA.  A 1.0A LDO regulator costs very little, and 1.0A represents a very safe overdesign for the combined needs of the W5100 and the CPLD.  This regulator is less than $.25 in 1K quantity, and it is stable with ceramic capacitors.
Xilinx has a tool called XPA for analysing the power consumption of a CPLD or FPGA design.  You can access the software manual for XPA starting here.
thanks
Hope this helps...
-- Bob Elkind
SIGNATURE:
Summary:
Thanks Bob,
Since I/O voltage for CPLD, W5100 and  TNT4882 are all same(means TTL compatible and 5V tolerant), I can directly connect I/O pins of CPLD to W5100 and TNT4882 devices,  Is it right? OR Is there any requirement for pull-up resistors on CPLD I/O pins?
Please let me know.
Thanks and Regards,
Prashant
Instructor
Instructor
I can directly connect I/O pins of CPLD (XC95144XL) to W5100 and TNT4882 devices,  Is it right?
Yes.
There is no requirement.
-- Bob Elkind
SIGNATURE:
Summary:
