theynab2015
Need help with Testbench
Hey guys.  I am trying to set up a test bench for my call and cncl buttons. (which are my inputs) . Both inputs call and cncl are initially 0.  Call becomes 1 for 2 cycles.  Both inputs are 0 for 2 more cycles, then cncl becomes 1 for 1 cycle.  Both inputs are 0 for 2 more cycles , then both inputs call and cncl become 1 for 2 cycles.  Both inputs become 0 for 1 last cycle.   Here is my code which gave me no errors.
I have an idea of how to set it up but keep getting weird simulation results. Thank you.
entity flight6 is
    Port ( call : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           cncl : in  STD_LOGIC;
           res : in  STD_LOGIC;
           light : out  STD_LOGIC);
end flight6;
architecture Behavioral of flight6 is
type state is (lightoff,lighton);
signal current_state, next_state : state :=lightoff;
begin
comb_process: process (current_state, call,cncl)
begin
case current_state is
when lightoff =>
light <= '0';
if call = '0' then
next_state <= lighton;
else next_state <= lightoff;
end if;
when lighton =>
light <= '1';
if not(call and cncl) = '1' then
else next_state <= lighton;
end if;
end case;
end process comb_process;
clk_process:process
begin
wait until (clk'event and clk='1');
if (res = '1') then
current_state <= lightoff;
elsif (clk'event and clk='1') then
current_state<=next_state;
end if;
end process clk_process;
end Behavioral;
arpansur
Hi @theynab2015,
Welcome to Xilinx Forums Community.
Coming to your query:
I tried with following testbench for your code.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY tb_forum IS
END tb_forum;
ARCHITECTURE behavior OF tb_forum IS
COMPONENT flight6
PORT(
call : IN std_logic;
clk : IN std_logic;
cncl : IN std_logic;
res : IN std_logic;
light : OUT std_logic
END COMPONENT;
--Inputs
signal call : std_logic := '0';
signal clk : std_logic := '0';
signal cncl : std_logic := '0';
signal res : std_logic := '0';
--Outputs
signal light : std_logic;
-- Clock period definitions
constant clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: flight6 PORT MAP (
call => call,
clk => clk,
cncl => cncl,
res => res,
light => light
-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100 ns.
res<='1';
wait for clk_period*10;
res<='0';
call<='0';
cncl<='0';
call<='1';
wait for clk_period*2;
call<='0';
cncl<='0';
--call<='0';
cncl<='1';
wait for clk_period*1;
call<='0';
cncl<='0';
call<='1';
cncl<='1';
call<='0';
cncl<='0';
-- insert stimulus here
wait;
end process;
END;
Attaching the snapshot of the testbench. Please verify if the testbench results are the expected results else let us know your requirements.
Arpan
Arpan
arpansur
Hi @theynab2015,
LIBRARY ieee;
ENTITY tb_forum IS
END tb_forum;
COMPONENT flight6
PORT(
clk : IN std_logic;
res : IN std_logic;
END COMPONENT;
--Inputs
--Outputs
BEGIN
call => call,
clk => clk,
cncl => cncl,
res => res,
light => light
begin
clk <= '0';
clk <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
res<='1';
res<='0';
call<='0';
cncl<='0';
call<='1';
call<='0';
cncl<='0';
--call<='0';
cncl<='1';
call<='0';
cncl<='0';
call<='1';
cncl<='1';
call<='0';
cncl<='0';
wait;
end process;
END;
Arpan
Arpan
aher
Please refer XAPP given in this AR for efficient test bench writing.
http://www.xilinx.com/support/documentation/application_notes/xapp199.pdf
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
theynab2015
Hey sorry for the delay but the testbench is positive. Thank you.  I was wondering how do you  change the name under "value" to make it say light on and light off.  when i try , it doesn't allow me to edit to add names to the other states. btw i am using version 14.1  thank you
arpansur
Hi @theynab2015,
Please go through the attached snapshot. Please let me know if you need more details on this.
Arpan
Arpan
