nag.chil
Pcie XBMD Config
Hello i have been working on PCIe XBMD design..
After loading the module I have observed that Configuration space of FPGA shows pin A routed to 11
lspci in linux terminal shows pin A routed to 16.
Why can anybody can say the reason.....??
Which one is correct one...
sethus
Please refer to the below doc and follow the procedure and see if you see the same behaviour
https://www.xilinx.com/support/documentation/application_notes/xapp1052.pdf
BMD design drivers and application are tested on fedora 10.
Sethu
