naveengk14
Post synthesis
utilization after Post synthesis  is nothing but Utilization after Implementations ..?
Naveen G K
syedz
@naveengk14,
Can you please share the utilization report?
I suspect that design has dcp or netlist files which will be considered as black box during synthesis. Hence you wont see the accurate/correct numbers.
The utilization will be correct in post implementation reports.
--Syed
svanapar
@naveengk14
Refer https://forums.xilinx.com/t5/Implementation/Vivado-2013-4-utilization-reports/td-p/475408 for more explanation on synthesis utilization report.
Sravanthi
saradapr
Hi @naveengk14,
Hope below link helps.
https://forums.xilinx.com/t5/Implementation/Different-logic-utilization-after-synthesis-and-implementation/td-p/597343
Sarada
muzaffer
@naveengk14
your question is not very clear. Do you mean utilization post synthesis is zero ? Or are you asking if it is the same value as after implementation ?
If former, there might be blocks which are not included in your report because they're not fully implemented yet but it still shouldn't be zero.
athandr
If your question is if these are same or different, then the answer is No, the utilization post synthesis and after implementation are different. Post synthesis utilzation is just an estimate, the actual utilization is when the logic is put on the FPGA and this is the correct indication of your resource utilization.
Anirudh
