markbanchy
Problems generating BSP for UCOS in SDK 16.4, Zynq 7000
I'm attempting to setup a project using the uC RTOS on the Zynq 7000. I'm following this tutorial (https://doc.micrium.com/display/UCOSXSDK/uCOS+BSP+on+the+Zynq-7000+Tutorial) but receive the following errors when attempting to generate the BSP in SDK. For reference, UCOS is v1.41 while Vivado + XSDK is v2016.4.
Description	Resource	Path	Location	Type
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 419	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 462	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 498	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 529	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 559	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 600	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 633	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 658	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 684	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 712	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'int'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 741	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'unsigned'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 765	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'unsigned'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 798	C/C++ Problem
expected '=', ',', ';', 'asm' or '__attribute__' before 'void'	xdmaps.c	/test_design_sdk_bsp/ps7_cortexa9_0/libsrc/dmaps_v2_3/src	line 431	C/C++ Problem
make: *** [ps7_cortexa9_0/libsrc/dmaps_v2_3/src/make.libs] Error 2	test_design_sdk_bsp		 	C/C++ Problem
make: Target `all' not remade because of errors.	test_design_sdk_bsp		 	C/C++ Problem
make[1]: *** [xdmaps.o] Error 1	test_design_sdk_bsp		 	C/C++ Problem
make[1]: Target `libs' not remade because of errors.	test_design_sdk_bsp		 	C/C++ Problem
My hunch is that it has something to do with a path mismatch but I'm struggling to find where/what could be the problem. I'll also admit this is my first time working with an FPGA and the associated process, so this is all a bit unfamiliar to me.
Any help or advice would be beneficial.
Best,
Mark
