stanzani
Registration issue
a colleague of mine is trying to register with no joy: on clicking on the registration link the system reply with 'Authentication failure' etc.
Moreover the captcha testbox always states failure when th captcha is correct ... he tried to register again with a different mail address and did not receive anything
please help
balkris
it may be issue with browser . you can try chrome or IE
Thanks and Regards
Balkrishan
arpansur
Hi @stanzani,
Can you please suggest him to delete the caches.
We have a similar discussion in https://forums.xilinx.com/t5/Welcome-Join/authentication-failed-when-logging-into-the-forum/td-p/777433
Arpan
Naiba
I try to fill in the details but it keeps showing error . need help
anatoli
Hello @Naiba ,
What exact error do you see in your case? Please share a screenshot, if possible? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @Naiba ,
Were you able to resolve your issue after all? If not, please let us know and we can help you further on resolving this issue then.
Kind Regards,
Anatoli Curran,
Versal Blogs
