dpandya9488
USB2.0 Interface IP Core for Kintex7 Device (slave device)
I am designing a custom board where the Kintex7 is interfaced with a processor over USB2.0 interface.
The processor has USB2.0 host and I want Kintex7 device to function as USB2.0 slave device.
I want to know that which IP core will be suitable for Kintex7 as slave device..? Can anyone help me with this..?
Dhara
balkris
you can check this IP
https://www.xilinx.com/video/hardware/axi-usb-2_0-device-ip-overview.html
Thanks and Regards
Balkrishan
dpandya9488
Many thanks for your reply.
I referred the video and have understood that using this IP core will establish the USB interface between the FPGA and Host USB processor in my design.
But still I need to confirm that if I am using this IP core with FPGA then will I still need any external PHY devices between the processor and FPGA..??
Dhara
