concattocarol
Ultrascale Tranceiver Example problem
Hi I am simulation the Ultrascale tranceiver and the. I am using the example generated by vivado.
Screenshot from 2016-10-21 13:31:25.png
Here is TX
Screenshot from 2016-10-21 13:22:11.png
And RXScreenshot from 2016-10-21 13:23:15.png
Do I need to do something in order to make it work?
I can see the RX is not align. Do I need to do something in order to align? This is just the example, I've changed anything.
concattocarol
So I added a MAC layer on the previus IP. And I only start to send data after the signal rxchannelisaligned is set to 1.
It seems to solve part of the problem. However now I have to issues, because the packet on the RX is shited to the right. An I receive on piece of frame correct and another incorrect, one correct and another incorret.
Screenshot from 2016-10-28 15:13:51.png
Screenshot from 2016-10-28 15:14:09.png
concattocarol
You can see in the figure that the packet Fbaaaaaaaaa.... after being deserialized on the RX is d55555555555.... It seems the the data is shifted.
