Unable to access On demand training courses
https://xilinxprod-catalog.netexam.com/Training/Filter
The link to the courses do not work, can't access any of them for registration.
Re: The same situation is happening to me.
Hello @sqrtof2 @sicnarf ,
The new link is this one: https://www.xilinx.com/training/customer-training.html
This is the new Xilinx Customer Training Center to access our library of training.
Is this what you are looking for?
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Can someone help us?
Below is the error code:
Server Error in '/' Application.
Method not found: 'Int32 Catalog.Core.Service.ICourseService.UserEligibleForCourseware(System.String, Int32, System.String)'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.MissingMethodException: Method not found: 'Int32 Catalog.Core.Service.ICourseService.UserEligibleForCourseware(System.String, Int32, System.String)'.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[MissingMethodException: Method not found: 'Int32 Catalog.Core.Service.ICourseService.UserEligibleForCourseware(System.String, Int32, System.String)'.]
   Catalog.Web.UI.Controllers.CertificationController.Details(Int32 id, String certificationName) +0
   lambda_method(Closure , ControllerBase , Object[] ) +195
   System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +229
   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35
   System.Web.Mvc.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() +80
   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +454
   System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +973
   System.Web.Mvc.Controller.ExecuteCore() +128
   Catalog.Web.UI.Controllers.BaseController.ExecuteCore() +1348
   System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +235
   System.Web.Mvc.Async.AsyncResultWrapper.<.cctor>b__0(IAsyncResult asyncResult, Action action) +24
   System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +38
   System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +43
   System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +73
   System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +38
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +602
   System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +195
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +128
Hope this helps.
Kind Regards,
Anatoli Curran,
@anatoli, the new link does not seem to work as well. I am still getting the same error message.
Hello @sqrtof2 ,
Looks like you need to refresh your internet cache (Ctrl+F5 together) and then try once again?
Or, if this is an internet browser issue, would you have any other browser that you can try this link?
All seems to be working fine for me:
Hope this helps.
Kind Regards,
Anatoli Curran,
