Urgent - Development board suggestion for PWM
I need a Xilinx development board with FPGA for PWM having folloing please:
- 90 or more useful output pins at 3.3V
- Around 200 MHz digital outputs
- Ethernet port. The PWM signals will be reconfigured through this port.
Many thanks.
Re: Urgent - Development board suggestion for PWM
Many thanks for this help.
Advisor
Advisor
I'm a big fan of the MicroZed fpga module.  You would have to make a simple carrier card to use the I/O pins but there about 100 that can be powered by 3.3V I think.  You can get it with a Zynq 7010 or 7020. The 7010 version is very affordable.
DSP in hardware and software
