VC707 BOARD
Does FMC XM105 Debug caard support VC707 Board? iWhere can i get ucf file that card/
Re: VC707 BOARD
yes, xm105 is suported with vc707 board.
Check below link.
http://www.xilinx.com/products/boards-and-kits/fmc-cards.html#interfaceperipherals
Scholar pratham
Re: VC707 BOARD
@rajuponnaganti User guide
http://www.xilinx.com/support/documentation/boards_and_kits/ug537.pdf
-Pratham
Re: VC707 BOARD
Does 4- Port SFP + FMC Module (HTG -FMC- X4SFP+) support VC707 Board?
Re: VC707 BOARD
Yes it is supported.
Check this below link,
http://www.xilinx.com/products/boards-and-kits/fmc-cards.html#serialconnectivity
I see that you opened new thread on this same query, pelase clsoe this thread by marking the answer.
Re: VC707 BOARD
I need reference design to use this FMC daughter card.
