Visitor 583774387
Vivado hls co-simulation fail
Hi guys,
I use vivado 2014.4 32bit, I was implementing FE method, when I ran co-simulation, the process got stuck, and I got warnings :
Warning: OPMODE Input Warning : The OPMODE 00100UU with CARRYINSEL  000 to DSP48E1 instance is invalid.
what does that mean? how can I fix that?
Thanks in advance!
Teacher xilinxacct
Re: Vivado hls co-simulation fail
@583774387
Similar item here... https://forums.xilinx.com/t5/Simulation-and-Verification/Warning-OPMODE-Input-Warning-The-OPMODE-0110X0X-with-CARRYINSEL/td-p/702538
Hope that helps
If so, please mark as solution accepted to close the issue. Kudos also weclomed. :-)
