Vivado: not enough memory
Greetings,
I am using a .tcl script that triggers an ILA, and then calls a unix shell script that processes the .csv file that the .tcl script has written. This happens periodically, and I have created an infinite loop in the .tcl script, in order to trigger periodically and get the data I want from the .csv file.
However, as the script runs, the memory consumption of Vivado (2017.1) is rising continuously, and when it reaches ~85% of the total system memory, I get this from Vivado: couldn't fork child process: not enough memory while executing "exec /bin/csh -c $script_location"
Is there any workaround? Can I write the script in a different way so that I don't have to restart Vivado and the script every 15 minutes?
.tcl script:
set numberOfFiles 3;
set timeout1      100;
set timeout2      10000;
set targetDirectory /home/test
set script_location /home/test/script.csh
    puts "---- BEGIN -----"
    #numberOfFiles does not change, hence infinite loop
    while {$numberOfFiles > 0} {
        run_hw_ila [get_hw_ilas hw_ila_1] -trigger_now
        # writes the file
        write_hw_ila_data -csv_file -force $targetDirectory/data [upload_hw_ila_data hw_ila_1]
        for {set i 0} {$i < $timeout1} {incr i} {
            puts ".....timeout1...."
        #executes script that processes the .csv file
        for {set j 0} {$j < $timeout2} {incr j} {
            puts ".....timeout2...."
    puts "---- END -----"
Cheers
Tags (3)
