Participant mao_jacky
Where is the setting of Placement-Seed?
Hi,all
   I want to set the Placement-Seed. Where is the setting in ISE?
Re: Where is the setting of Placement-Seed?
Hi @mao_jacky,
You can change the placer cost table from 1 to 100 for using different seed.
Default value is 1. The place cost table can be accessed using "-t" option.
To change this value:
  1. Right click on Implement Design->Process properties
  2. Map properties. Go to -t option and change the value. Attaching a snapshot for your reference.
Please go through a similar thread https://forums.xilinx.com/t5/Implementation/MAP-Cost-Tables/td-p/208409
Arpan
check this ARs
https://www.xilinx.com/support/answers/35534.html
Thanks and Regards
Balkrishan
Hi @mao_jacky,
Arpan
