08-07-2015 06:39 AM
I am trying to read analog signals by using the XADC. I have Zynq-7000 board. I could not find the pin assignment document. To input the analog signal to the 16 channels from, vaux0 to vaux15, how should I make the input connection with the XADC Header?
Thanks a lot. :)
08-09-2015 10:28 AM
08-09-2015 10:28 AM
08-10-2015 02:45 AM
Thanks for the answer. It is Z-7020. I saw the link below:
http://microzed.org/sites/default/files/documentations/ZedBoard_RevD.2_Schematic_130516.pdf
Still I could not figure out where is bank 35 on the board, how can I make the physical connection of the analog signal with the board?
08-10-2015 02:55 AM
08-10-2015 03:20 AM
In page 9, for the XC7Z020_CLG_484 in the bank 35, it shows AD(some_number_X)N or P as input pins. I still dont get where they correspond to on the board.
11-29-2016 11:44 PM
11-30-2016 12:46 AM
What exactly is your issue? Just share what you are trying to do and board you using to make sure you referring to same board as above.
11-30-2016 01:13 AM
11-30-2016 01:19 AM
11-30-2016 01:43 AM
@mohamed.omran You need to make the necessary circuit to make sure the input is between 0-1 volt for Unipolar operation.
So based on what you are trying to measure, you may need to scale it using resistor divider network to bring it within the operation range.
Go through UG480 http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf and it has the necessary details.
