ghvr1521
Zynq Supply VCC3V3 is shorted with ground
In Zynq,  IC27 VCC3V3 is getting shorted with Ground during ON/OFF of board [ Board is not connected to any external Circuit] Observed same scenario in 3 board. Any helpful to suggestion to debug or How to avoid this to not to happen again ..
Thanks in advance.
Harshavardhan.
Tags (2)
muzaffer
@ghvr1521
This is not a clear description (at least to me). What does "getting shorted with ground" mean? How do you observe this? What is the consequence? Which Zynq system is this, Xilinx devkit or custom ?
