kpench
Zynq XC7Z020 reset scheme with watchdog
Please let us know is there any reference design with XC7Z020 reset scheme with watchdog.
Pench
umamahe
Please search the reference designs in the following ZC702 board link page http://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation . (In the above board link check the reference designs type in "Document Type" Box to view the example reference designs.
FYI: Refering the below topics gives more clarity about  Zynq XC7Z020 reset ( watchdog )
Page 227 (8.2.3 Resets) in http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf.
Reset Effects table in page 678 in the above TRM is useful information
umamahe
