call back function in system generator
i am designing 4 tap filter in system generator its callback function is not working. the call back function includes the following code
STOP FUNCTION
 doFFTplot(fs,[FIROUT],['FIROUT'],1,3);
set(3,'Name','FFT Plot of Filter Impulse Response','NumberTitle','off');
setStandardFigSize(3);
 what should i do to remove these errors.
thanks for help in advance
Re: call back function in system generator
What is the error?
www.xilinx.com
these are the following 2 erros that appear in this design ....
Here's the problem:
"Undefined function or method 'doFFTplot' for input arguments of type 'double'"
You need the code for 'doFFTplot' to be located in your working directory (or in your matlab PATH)
www.xilinx.com
