clock in spartan
what i have to do to use on board clock in spartan series
is gclk for that purpose
Historian
Historian
Re: clock in spartan
Spartan FPGAs do not have onboard clocks. You must provide one. You should use the GCLK pins, following the various rules. See the documentation for the specific device.
Historian
Historian
Hi Lino,
Please don't ask the same query in multiple boards.
As you already have a discussion going about the clocking in below board.
http://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/clock-input-in-spartan-3/m-p/409771#M8570
Satish
