for loop ends without iterations
Hay! I'm using for loop with veriable counter_iteration which i'm also taking as output from the module and using reg output as register. In simulation as I leave reset state for loop get jump to its last value 65. I'm attaching code. please help
Tags (3)
You, like many others, are thinking with a software mindset and not a hardware mindset. In hardware, loops are not dynamic they are unrolled and made static as hardware is static. So, everything in the for loop happened with no delay and the final result is shown as 65.
Loops in HDL should be used sparingly and generally for simplifying the instantiation of multiple blocks.
Itsdoesn't complete iterations . Registers' value goes 65 from 0
Here is the Simulation
well that sucks !! But I got you point ! That all of the Loop iterations would be executed in one cycle .... But then we can't really say it a aloop as every Programming Language has them !!Thanx for pointing it out anyway ! I wasn't thinking about this point !!
Historian
Historian
It doesn't suck. It's the way the language works, and that's because it describes hardware, not software on a sequential-exection machine.
Ed is correct: you're thinking like a software programmer and not a hardware engineer.
u r saying that for loop will be unrolled and will be executed in parallel..if that is the case then how data dependency resolved. want say it takes into account data dependecy or not? eg Ripple carry addet using for loop will work or not?
Thanks evrybody
