hardware target detected but no hardware device found
 I just got an HTG-K800 xilinx board with xcku115 ultrasclae part.
 when i open the hardware manager (vivado 2015.4) and do the auto connect i get following message.
ERROR: [Labtools 27-2269] No devices detected on target localhost:3121/xilinx_tcf/Xilinx/00001865c3d601.
Check cable connectivity and that the target board is powered up then
use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
ERROR: [Labtools 27-55] Invalid index 0 passed to getDevice
I am also using the latest JTAG cable DLC10 (also tried using DLC9g the black one)
I have not attached any FMC cards. This a brand new board
Attached are the screen shots. Appreciate your quick help.
Kannan
Re: hardware target detected but no hardware device found
Hello @kannan.govindasamy,
Have you checked possible reasons for this issue on page #25 from below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug908-vivado-programming-debugging.pdf
Ashish
Hi @kannan.govindasamy
Try reducing the JTAG speed and see if that helps.
Thanks,Vijay
Hi Ashish,
Had tried all those reducing the JTAG frequency to no effect.
When tried following the AR (adding third party jtag ) the hw_server command is running forever.
http://www.xilinx.com/support/answers/61312.html
Attached is the screen shot of that.
Kannan
