Anonymous
Not applicable
ila debug core clock problem
Hi everyone,
I run into a problem with ila debug core.
I design for a Zedboard and I am using Vivado 2013.3 and I try to capture some signals coming out of a custom IP I designed.
The clock (clk_out1) of this IP is 10 Mhz, coming from a clocking wizard.
The input clock (sys_clk) of the wizard is the 100 Mhz system clock of the board (pin Y9).
 I set up the debug core with clk_out1 as the clock domain of the signals.
When I try to capture the signals, by pressing "run trigger" in the hardware manager nothing happens.
If I set the 100 Mhz sys_clk as the clock domain for the signals, the capture is working but of course it is oversampling.
Why the debug core is not working with the clock coming out of the clocking wizard, but only with the system clock (going in the clocking wizard)?
Re: ila debug core clock problem
The JTAG cable’s TCK clock frequency has to be lower than the ILA’s “clk” input frequency.
Which cable are you using? If the default cable frequency is greater than 10Mhz(ILA clock frequency), try setting it to a lower value.
Deepika.
Deepika.
Deepika.
Deepika.
Anonymous
Not applicable
This solved the problem.
Nikos
can you tell me , how to use ila,  give me a example,thanks.
my email:  yinfuyou198947@sina.com
                                     thanks.
Here is a nice tutorial: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug936-vivado-tutorial-programming-debugging.pdf
Vinay
First go through chapter #4 from below UG to get the overview of ILA and then do the above mentioned tutorial
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug908-vivado-programming-debugging.pdf
Ashish
Accept as solution - thanks
Yup, this one just bit me in the behind as well, yup also wasted a lot of time like the others -
Having ported a working design from old Kintex to new Zynq target, I didn't notice that though old Zylinx box was 5MHz, the new Diligent (I just discovered) was defaulting to 15MHz ... setting back to 5MHz got the ILA working again.
Now I just have to rant to Xilinx a little as Vivado (2015.1) has cause me a lot of wasted time over the last month, in many ways:
Why cant the tools help us out a little here, and not just stare back at us with that now familiar blank expression!
And at a more fundamental level, why is the ILS so intimately tied to the JTAG frequency? is it to save on memory or other resources? I have resources to burn in this test project! I remember in a Quartus project (2011 version that is!) completly starting & stopping my SignalTap sample clock with impunity via my own logic to skip non-required states, and mux in different clock divider rates for more/less detail in specific states - all of this to conserve precious trace buffer on a small target (and it made it easier to navigate around the resulting scope) - and it worked flawlessly! Never had to even think about the minimum clock frequencies.
Voyager
Voyager
Really works. Solution Accepted. Thank you Forum people. Thanks Deepika
-Sampath
Thanks deepika.
@vemulad
Thank you Deepika. It worked.
