08-31-2016 08:02 PM
I use xilinx ISE14.4 core ip V3.2 REV8 and windows7 condition.
using the displayport UHD(3840X2160) module normal operate 4 LANE 5.4Ghz.
but frontporch value less then 20 problem occured.
timing is below.
DotClock:533.28Mhz
H total : 4000 V total :2222
H display:3840 V display :2160
H back porch :112 V back porch :3
H sync width : 32 V sync width :5
H front porch :16 V front porch : 54
H frequency : 133.32 Khz V frequency : 60 hz
but the h front porch more then 20 is no problem.
is there a person who has this experience?
but time is not problem because is time not problem because chked by oscilloscope.
how to solve ?? T T
please answer the replay any idea.
dgshin@e-uplus.co.kr
08-31-2016 08:56 PM - edited 09-01-2016 12:10 AM
Hi jesushand
I have some questions to resolve this issue.
Could you tell me them ?
Q1) What device or LCD monitor do you use ?
Q2) Does LCD device or LCD monitor have some tolerant for UHD(3840x2160) ?
Q3) How do you calculate video timing ?
Q4) What mode do you use ? (8bit RGB or 8bit YUV444 or 8bit YUV422 or other) ?
Q5) Which IP do you debug ? DP IP Rx or DP IP Tx ?
If you debug DP IP Tx, I guess it's back end device issue. (LCD device or LCD monitor)
You should contact LCD device vendor or LCD monitor vendor, if possible.
Thank you.
09-28-2016 10:33 PM
-->kintex7 -2 (XC7K160T)
--> UHD 3840X2160
--> i have work pattern generate equipment. (my job)
so it is not problem another display operate. LVDS and VbyONE module nothing problem.
-->8BIT RGB
--> DP IP TX
I HAVE WORK FOR LG AND 3kind moudule same.
and LG DEVELOPE WORK NOTEHING module problem. PC BASE GRAPHIC CARD . nothing problem.
09-28-2016 11:15 PM
->kintex7 -2 (XC7K160T) it is LCD test pattern generate use.
--> this equipment many kind displayport LCD module test machine.
LCD monitor test LG, BOE, and another made test same.
