bri@n
new to FPGA
I am keen to start with FPGA's.  I am mainly looking to add use them to add some research capability to my flash memory lab.
I have done quite a bit of reading, starting at the very lowest rung with some FPGA101 tutorials, reading datasheets, user forums discussing various dev boards.
The first project I want to do seems simple, but I doubt it will be!  I want to be able to read contents of a StrataFlash chip (external to board).  I have seen the PicoBlaze project for the 3E. and forum posts like:
Spartan-Family-FPGAs/Reading-and-writing-to-Flash-on-Spartan-3E-starter-kit
Nexys2-writing-flash-issue-Help
These may be helpful, but I don't have enough information to decide yet.  Also, I am wondering if newer FPGA boards, or simpler boards may be a better choice, as I don't want to write config data to onboard flash, I dont need any other functionality, and possibly newer devices may be easier/better supported/better in general to use...
Can anyone suggest a suitable minimum spec board to start with?  Basically I have various StrataFlash chips and I want to read the contents (dump them).  I know there are probably programmers available, but the goal is to also get a step into FPGA's for future similar projects.  Do I really need a 3E based device or is that just what the project author decided to go with?  I see StrataFlash used in places like holding config data for routers, in phones etc, so I am hoping a simple reader shouldnt need a complex/expensive board, or "too hard" of a dev learning curve.
It has been very interesting reading through these forums, and thanks to all cluey guys and gals offering their time to us greenhorns!
Best regards,
Brian
pratham
bri@n You may get started with an inexpensive ARTY board.
https://www.xilinx.com/products/boards-and-kits/arty.html
This board has got 16MB QSPI flash. You can also use the existing designs to learn and perform the read/write on the flash using FPGA. If I were you, I would go for 7 series FPGA and inexpensive board to start with.
-Pratham
vijayak
Hi bri@n
Its all depends on how much logic you want to implement.
I suggest you to get in touch with nearest sales/distributor office for a formal discussion on your requirement and they will be able to help you to choose the board that can cater your future design requirements as well.
https://www.xilinx.com/about/contact.html
Thanks,Vijay
balkris
Spartan 3E are older device and will not be support in future. I would recommend you use Vivado tool and latest device.
StrataFlash information you can find in these documents
https://www.xilinx.com/products/boards/s3e1600e/PicoBlaze_NOR_FLASH_programmer_1600E_rev1.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp1106.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp963.pdf
You can find Vivado information here
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0002-vivado-design-flows-overview-hub.html
Board and kits information available here
https://www.xilinx.com/products/boards-and-kits.html
Thanks and Regards
Balkrishan
bri@n
Thank you Vijay and Balkrishan for your answers, I appreciate you taking time to help.  I am wondering if maybe I need to try a forum with a more hobby-based outlook.  I think these forums may be biased more to industry/engineering of a larger scale.
Vijay, thank you, I understand the suggestion, and normally it would be probably the wisest choice, but I dont think a sales rep would want to spend valuable time consulting when I really want a pretty basic solution, and have no real possibility of other purchases for a while until I get more, much more! experience in FPGAs.  I was hoping a forum might be able to just give a nudge to a starter/simple board and some SDK to get going.
Balkrishan, I also thought to choose a modern, current board and IDE, I agree there.  I had seen all the Strataflash references and read through them.  If I used those as a base reference, I think I would be in trouble as the use case is quite different - simply reading an external strataflash chip and saving dump. I would need to port/modify a lot for a current board, and without FPGA experience I think it would be quite difficult.  Even deciding on a board that only really does what I need, and isnt overkill, but does support my project goal wouldnt currently be possible.
I hope I don't appear to be being difficult! I Thank you for the links, I am reading through them.
Best regards, Brian
pratham
-Pratham
bri@n
Thank You Pratham. I know my question was quite vague in nature. for the price, it looks like a very flexible board. I think it probably has more than I need for what I want to do, but just re-reading the first 2 replies, I think the sentiment of getting something that can also be used in future is smarter.. Thanks everyone for your support.
