alitunc
petalinux 2017.1 faild to generate kconfig
Hello all,
I have recently installed petalinux 2017.1 on ubuntu 16.04. Also create project with avnet-digilent-zedboard-v2017.1-final.bsp for Zedboard. But when i ran petalinux-config or petalinux-build it returns kconfig error at below.
dell@u1604:~/workspace/Petalinux/avnet-digilent-zedboard-2017.1$ petalinux-config
[INFO] generating Kconfig for project
ERROR: Failed to generate /home/dell/workspace/Petalinux/avnet-digilent-zedboard-2017.1/build/misc/config/Kconfig.syshw
ERROR: Failed to Kconfig project
ERROR: Failed to config project.
Any idea for this issue?
stephenm
 you post the petalinux_installation_log please?
bryanloz
I got these same errors.. when:
After installing Petalinux to some directory... I realized that I should have put it in a folder that indicated its version...
I did: mkdir 20172
And I moved all of the created files into the new directory...
Things just wouldn't work after this. I redid the install in the directory where I really wanted it this time, and everything started working.
