vineethegde009
power dissipation artix7 XC7A200T-2FFG1156I
Please provide the typical and maximum power dissipation value for artix7 XC7A200T-2FFG1156I FPGA.
Vineeth
saradapr
Hi @vineethegde009,
Max power dissipation is based on the amount of heat that a device can tolerate. You can use wither XPA within ISE if you have a design ready or you can use the XPE Spreadsheets at www.xilinx.com/power if you want an estimate of what the power could be in a particular device with a particular design.
It depends on you no of logic used by your application.
Sarada
gnarahar
@vineethegde009 To add to above, you may want to go through these links for a better understanding
http://www.xilinx.com/video/hardware/using-the-xilinx-power-estimator.html
http://www.xilinx.com/video/hardware/power-estimation-analysis-using-vivado.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug440-xilinx-power-estimator.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug997-vivado-power-analysis-optimization-tutorial.pdf
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
