shridharsk
revision stack
Where I can get revision stack. Is it a part of SDSOC 2016.4
What all tools(like SDSOC, VIVADO) required to get started using the revision?
balkris
check this Video
https://forums.xilinx.com/t5/Xcell-Daily-Blog/What-can-you-do-with-the-new-Xilinx-reVISION-stack-for-embedded/ba-p/754415
Thanks and Regards
Balkrishan
shridharsk
that is general introductory video of revision stack.
Doesn't say anything about where to get it.
balkris
This is not release yet tentatively in Vivado 2017.1/2017.2 release. This will be supported in SDSOC and SDAccel
Thanks and Regards
Balkrishan
