simulation failed. contact tcl store
dear all..,
i have installed  vivado 2015.1 and loaded licence file and it is working but when iam trying to share this licence to other systems vis LAN it is not working.....the licence is purchased of 25 users ..i used syntax as 2100@server IP address in client systems.....can someone help me..
here attaching licence file..
Re: simulation failed. contact tcl store
It seems from the license that you have attached, it is nodelocked and is not floating.
Can you please check if you have attached the correct license?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
