unable to use the software
Its hang/crash issue. are . Can you please try with latest version ISE 14.7 .
It seems you are using pretty old version of ISE
check these ARs
http://www.xilinx.com/support/answers/32308.html
http://www.xilinx.com/support/answers/36233.html
check this link as well
https://forums.xilinx.com/t5/Installation-and-Licensing/ISE-17-7-Webpack-ngdbuild-exe-has-stopped-working-APPCRASH-in/td-p/500182
Thanks and Regards
Balkrishan
Hi @sanghamitradebnath6
Which OS are you using?
Also which version of ISE?
Here is an answer record that discuss on how to install and use ISE 10.1 or ISE 14.7 on windows 8.1 or windows 10 machine: http://www.xilinx.com/support/answers/62380.html
Vinay
i m using windows 7
