naveengk14
virtual clock
Hi all,
What is Virtual Clock...?
why it is used..?
Naveen G K
arpansur
Hi @naveengk14,
Please go through page 62 of following link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_1/ug903-vivado-using-constraints.pdf
also go through following link to get an idea of it's usage
http://www.xilinx.com/support/answers/55287.html
Arpan
Arpan
syedz
@naveengk14,
Check the following forum thread:
https://forums.xilinx.com/t5/Vivado-TCL-Community/About-propagated-attribute/td-p/253702
--Syed
yashp
Virtual clocks are clocks without source objects/as name states without physical existence.
When you have any path coming outside the FPGA and without registered any data going outside the FPGA.
INPUT PAD --> Combination logic --> OUTPUT PAD so to analyze the timing you need some reference and then Virtual clocks comes into picture.
Yash
arpansur
Hi @naveengk14,
Is your query addressed?
If your query is addressed please close this thread by marking "Accept as solution" to the answer that addressed your query.
Arpan
Arpan
