whether rand and srand library function will work or not in vivado HLS ?
I am using rand and srand library function to generate random bits. I have referred Xilinx forums in that mentioned only srand()/rand() requires about 256 Bytesof heap to work. But i seems that its work in hls. Not sure !
While synthesizing i am getting error "Please go through the attached screen shot"
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include "ap_cint.h"
int SRAND(unsigned bit) {
#pragma HLS INTERFACE s_axilite port=bit bundle=a
#pragma HLS INTERFACE s_axilite port=return bundle=a
        int i;
        srand((unsigned) time(NULL));
        for (i = 0; i < 100; i++)
#pragma HLS PIPELINE
            bit= rand() % 2;
        //    printf("%d", bit);
return bit;
Scholar u4223374
Re: whether rand and srand library function will work or not in vivado HLS ?
No, they're not supported in HLS. You can write your own pseudo random number generator using a linear feedback shift register if you need to. Time.h is also not supported; the FPGA has no real concept of time.
Scholar u4223374
