vivek85628
xilinx ise 14.2simulation problem
In the ISE design suit 14.2(ISE project nevigator) when I click on open project or add source option,  ISE nevigator terminated that is ISE window closed.
Please suggest me solution for this problem.
anusheel
@vivek85628
We have not tested ISE 14.2 with Windows 8.1 OS. Try using ISE 14.7 (which is also not supported with Windows 8.1) and see if you able to add the sources.
Anusheel
Helpful answer -> Give Kudos
anusheel
@vivek85628
Which OS are you using?
Anusheel
vivek85628
I am using windows 8.1 os.
anusheel
@vivek85628
You are not using supported OS. Below are the supported OS:
Anusheel
vivek85628
Is there any solution for this problem for windows 8.1  os.
Vivek
anusheel
@vivek85628
Anusheel
